HI I just did a engine swap on my accord it has a f23a1 2.3 sohc w/vtech I got a jdm engine and it was a f23 sohc w/vtech. I only used the new engines block as my car was still running when I did this, anyway I am about to power it up, and I am wondering is there anything special like resetting the computer, or something else I should do. Also I had removed the distributor and for got to mark its position but there are only two possible ways for it to go on and I believe it is with the line on the distributor pointing towards the little "o" mark on the cam is this correct? Thanks for your help! [img:5e6b069cba]http://www.2carpros.com/forum/automotive_pictures/193567_parts_1.jpg[/img:5e6b069cba]
May 23, 2008 at 9:12 AM
