1999 Honda Accord electric locks
185,000 MILES • 4 CYL • FWD • MANUAL
DACHLLO
The door lock on the rear driver side does not lock or unlock with either the key remote or the switch on the driver door. Is there a fuse to replace or could it be something more complicated? Thank you.
Aug 3, 2009 at 2:20 PM
STEVEW84
  • 673 POSTS
Will it lock if you manually lock it, not with the key or remote?
Aug 4, 2009 at 12:20 AM
DACHLLO
stevew84,
Yes, it will lock or unlock if you physically push or pull on the "knob" but doesn't work if you use the key remote or the actual switch on the door.
Thanks.
Aug 4, 2009 at 9:19 AM
STEVEW84
  • 673 POSTS
I would be checking for a bad actuator. Take the door panel off and have someone lock and unlock the door and see if something is not moving.
Aug 4, 2009 at 9:31 AM
DACHLLO
Ironically, it worked okay on a couple of occasions this evening so I'm wondering if it's not an electrical issue. Does that sound right?
I'll monitor it closely and see if it continues.
Thanks again.
Aug 4, 2009 at 12:43 PM
STEVEW84
  • 673 POSTS
Sounds like an electrical issue. I would definently be looking at at an actuator problem.
Aug 4, 2009 at 12:52 PM
