Hi, my drivers side door lock does not work with the
remote. How do I replace the actuator?
Oct 6, 2008 at 5:00 AM
KHLOW2008
✓Experienced Mechanic
ACTUATORS
Removal & Installation
Remove "pull pocket" (handle) from door panel.
Disconnect harness connector from door switches.
Remove trim panel from door.
Remove plastic water shield cover.
Disconnect linkage and unplug harness connector from actuator.
Remove mounting screws and actuator.
To install, reverse removal procedure.
