Hi itsjaime,
You need to remove the 3 holding bolts, disconnect the wire connectors ans pull out the distributor.
When installing, make sure the distributor legs are in the correct direction, it is off set and should slide in easily. Reverse instalation would make it very difficult to go in.
After installation, you need to check the ignition timing.
SPONSORED LINKS
Saturday, November 15th, 2008 AT 10:54 AM
