Stalls while driving?
SWISSMISS
  • 1999 HONDA ACCORD
  • 4 CYL
  • FWD
  • 187,000 MILES
My honda has this intermittent problem it cuts off while driving sometimes when stopped and sometimes while parked you turn the key it fires up and immediately dies. I've replaced the ignition coil the ignition switch, maf sensor rotor bug and cap and still have this problem. Can you help me figure it out? I'm suppose to be heading out on road trip on thursday and don't feel comfortable taking it.
thank you
Sunday, September 27th, 2009 AT 5:20 PM
KHLOW2008
  • 41,814 POSTS
Hi SWISSMISS,
I would suggest checking the PGM-FI main relay.
https://www.2carpros.com/forum/automotive_pictures/192750_PGMFIRelay99Accord_2.jpg
Wednesday, September 30th, 2009 AT 2:04 PM
PHILA
Hi Swissmiss,
My 1999 Accord Ex 4cyl w/115K is now doing exactly the same thing that your car was doing. Intermittingly starts and dies, and also intermittingly stalls while driving. RPMs just go to zero with no codes or other symptoms. Did you ever resolve your problem? If so, would you be so kind as share the cure? Was it the main relay?
Thanks Phila
Tuesday, June 22nd, 2010 AT 12:52 PM
Related Engine Stall While Driving Content
