1999 Honda Accord Climate Control Lights off
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
RKUKREJA1
The Climate control that has toggle switches (with lights) for Rear defroster, A/C, etc, does not work. I mean, i cannot turn these buttons On or Off, the LED lights above it are not working. This does not let me select the button. The round knobs letting air blow in and selecting the temperature are fine. In addition, my clock is not illuminated. Is there a common fuse or wiring that I could fix?
thanks
rajesh
Oct 18, 2008 at 10:13 AM
KHLOW2008
  • 41,812 POSTS
Hi Rajesh,
There are no common fuse linking the control panel and the clock illumination. Clock illumination uses the lighting circuit and I believe the clock illuminator is bad if the lightings are wrking.
The AC controls should be a fault with the unit and you can try checking the # 13 fuse (7.5A) underdash passenger side.
Oct 24, 2008 at 5:09 AM
