1999 Honda Accord car turns off
MYCHULAS
Engine Mechanical problem
1999 Honda Accord 6 cyl Automatic
Hello, we have a 1999 Honda Accord. It seems to turn off completely while being driven. Everything completely shuts down. But the car is still in motion as if you are driving. It has been recalled in 2005 due to ignition switch. Could that problem cause the card to loose total power? It's scary to drive because you even lose the power brakes. What else could be causing this problem?
Any info would be greatly appreciated Thank you
Mar 12, 2009 at 6:07 PM
  • 75,988 POSTS
It has been recalled in 2005 due to ignition switch. Could that problem cause the card to loose total power-If the ignition switch goes all your switched power thru the ignition switch will be inoperative.
Other problems could do this such as the ignition and fuel system also the charging system
What is it doing now??? Will it start up or whatever is happening
Mar 12, 2009 at 7:40 PM
