1999 Honda Accord Car running hot
1999 HONDA ACCORD
202,000 MILES • 4 CYL • FWD • AUTOMATIC
MIKEMARC
I have an hour and a half drive to work. Half way here this morning, the temperature gauge started reading very hot, just under redline. It varied up and down along the way. I turned the heater (vent) on full to pull heat off the engine and made it to work. When I arrived at work, the engine was smoking so I opened the hood. It looked like coolant expoded all over the engine yet the resevoir was the same as it was before I left the house. What in the world could be going on and is it safe to try to drive all the way home after work today? Thanks.
Feb 24, 2009 at 1:13 AM
F4I_GUY
  • 3,302 POSTS
You probably have a coolant leak. Get your system pressure testing to find this leak.
Feb 24, 2009 at 9:45 AM
MIKEMARC
Yep, I had a hole in a hose. Thanks.
Feb 25, 2009 at 1:45 AM
F4I_GUY
  • 3,302 POSTS
No problem mikemarc! Glad you got it solved. It probably would be a good idea to replace all your coolant hoses to ensure this doesn't happen again.
Feb 25, 2009 at 11:16 AM
