1999 Honda Accord Blinkers
218,000 MILES • 6 CYL • FWD • AUTOMATIC
CMUSSAR
A couple of years ago, 2 deer ran into my front passenger side. I used a shotty repair man. My front headlight was replaced but there was a connection missing. The engine splash shield was also replaced at that time, but not correctly. When it decided to tear off all the way while driving 70 on the highway, it took the connection on the drivers side as well. Now, my front flashers do not work at all, and my rear flashers flash super fast. What do I need to fix the problem?
Mar 25, 2010 at 9:56 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the rear signal flashes fast because this indicates that a light is not working. the light that isn't working, obviously, is the passenger front signal. to repair it, you will have to run a new wire harness connector to replace the old wiring
Mar 25, 2010 at 9:59 AM
CMUSSAR
[quote:86fcf7ac9c="bluelightnin6"]the rear signal flashes fast because this indicates that a light is not working. the light that isn't working, obviously, is the passenger front signal. to repair it, you will have to run a new wire harness connector to replace the old wiring[/quote:86fcf7ac9c] Thank you for the response bluelightnin6. I've actually been looking for wiring harnesses on the internet, but I'm not sure of the exact one I'm looking for. Can you be more specific about the exact wire harness connector needed?
Mar 31, 2010 at 2:26 AM
BLUELIGHTNIN6
  • 16,542 POSTS
it will be the wiring that is all together there at the signal lamp assembly. don't think you will be able to find it new on internet. best bet would be to check with the dealer or go to local salvage yards to find it.
Mar 31, 2010 at 5:59 AM
