Air Conditioning problem
1999 Honda Accord 6 cyl Front Wheel Drive 77000 miles
My mother in law has a a/c problem. When I start the car you can hear, and see, that the compressor and cooling fans under the hood comes on. The inside blower does not. After about 3-4 seconds the compressor and outside cooling fans shut off and the inside blower comes on. When the inside fan comes on the A/C is ice cold, until the cooling in the lines is gone. If I bump the ignition between start and run the compressor and outside fans come on and then shuts off after a few seconds. I can keep the cold air coming as long as I bump the ignition switch every few seconds.
The car does have automatic climate control.
A second problem is that the inside blower will only operate on HIGH. I am thinking this could be the resistor down by the fan motor.
Jun 17, 2008 at 9:50 AM
