1999 Honda Accord ABS and Other Things
MCDEREM
Brakes problem
1999 Honda Accord 4 cyl 157000 miles
I have a '99 Honda Accord LX with 157k miles on it. In December it started to have a problem with idling. I live in the Chicago area and the weather was very cold this winter. I would start the car and typically when it was warmed up, the engine would start to rev while it was idling. I didn't have it repaired right away and now the problem has progressed to revving upon starting and it's pretty jumpy/jerky when I'm driving (when foot is off gas). My mechanic said this is due to some sort of filter needing replaced to the tune of $400. Sorry I don't remember the name of the filter.
Problem number two: This weekend while driving the ABS light went on and about four times within a 15 minute span of time my brakes were very iffy. I thought I wasn't going to stop. The ABS stutter did not go off (you know, the stutter that happens when the ABS is engaged), but my foot went all the way to the floor when breaking. My mechanic said he checked all fluid levels, etc. and that I need a new ABS module to the tune of a $1200 repair.
Does this sound correct? Thanks!
Mar 9, 2009 at 7:04 AM
KHLOW2008
  • 41,812 POSTS
Hi mcderem,
The surging could be due to:
1. Insufficient coolant in radiator system
2. Stuck Intake Air Control (IAC) valve. If no codes are shown, cleaning it might solve the problem.
3. Idle adjust screw out of adjustment. If the idling speed is too high, it would cause the surging when engine is warming up.
The ABS master pump seems to be faulty but did you get a scan done to find the cause of the malfunction indicator sowing?What was the error code retrieved?
Mar 14, 2009 at 9:46 PM
