1999 Honda Accord 1999 honda accord car want start or crank
122,000 MILES • 6 CYL • 2WD • MANUAL
DADYHOME
1999 honda accord won't turn or start i got new starter and tested the battery.
Dec 17, 2008 at 11:48 AM
BRUCE HUNT
  • 3,754 POSTS
I am assuming that you are saying when you turn the key nothing happens? Right? If so, replacing the starter may not have been necessary but since that can be eliminated you might want to check the master fuse in the fusebox under the hood. Usually and 80 to 100 amp fuse. Check the connections and be sure they are tight and clean.
After that you are in to the ignition switch.
Dec 18, 2008 at 3:36 AM
