Maintence is on and it won't go off
CHERRYLYN
  • 1999 HONDA ACCORD
Engine Mechanical problem
1999 Honda Accord 4 cyl Automatic 170, 00 miles
My maintence is on and it won't go off I changed oil and oil filter What can it be for and how does it go off?
Thursday, October 16th, 2008 AT 5:00 PM
KHLOW2008
  • 41,814 POSTS
Hi Cherrylyn,
When distance driven since maintenance required indicator was reset is less than 6000 miles, the MAINT REQ'D reminder light will illuminate for 2 seconds and then go out when ignition switch is turned to ON (II) position. When mileage is 6000-7500 miles, MAINT REQ'D indicator light will illuminate for 2 seconds and then blink for 10 seconds when ignition switch is turned to ON (II) position. When mileage exceeds 7500 miles, MAINT REQ'D light illuminates and stays on while ignition switch is in ON (II) position.
To reset MAINT REQ'D indicator light, turn ignition switch to OFF position. Push and hold the SELECT/RESET button and turn ignition switch to ON (II) position. Continue to hold button for more than 10 seconds or until MAINT REQ'D light goes out.
Wednesday, October 22nd, 2008 AT 2:04 PM
