1998 Honda Accord WILL NOT GO
165,000 MILES • 4 CYL • 2WD • AUTOMATIC
DAVIDHOPKINS2006
Car started running bad about two weeks ago thought i had gotten bad gas, put in some fuel system cleaner didn't get better ( car would idle fine but when you needed to go it hesitated ) I ran a system check OBDII came up w/7 misfire codes an o2 code so I changed the plugs, distributer cap, rotor button, ignition coil ( it came up that code also) and o2 sensors still running bad so i took it to a shop the guy said i needed plug wires bad. So I got wires on the way to the shop put them on there ( I know the guy ) running bad even worse then originally his mechanic said the exhaust was stopped up so I went to an exhaust shop got a new catlatic? converter now it is running so bad i cant get it to make it up my driveway
Jun 2, 2008 at 8:43 AM
KHLOW2008
  • 41,812 POSTS
Hi davidhopkins2006,
It could be the TPS or MAP sensor that is not working well. Get a diagnostic data reading on their performance.
Check the fuel pressure too.
Jun 3, 2008 at 2:26 AM
