hear a "knocking" sound coming from my front left wheel when I press on the brakes
145,000 MILES • 4 CYL • FWD • MANUAL
1CLAYTON3
I have a 1998 Honda Accord and hear a "knocking" sound coming from my front left wheel when I press on the brakes to slow down. In addition, it is not my brake pads because I recently had them replaced. Need your suggestions.
Jun 25, 2008 at 6:49 PM
KHLOW2008
  • 41,812 POSTS
Hi 1clayton3,
If the knocking noise is repetitive while the wheels are turning, then most probably the rotor has a dent or bump along the edges.
If the knock is a one time noise each time the brake pedal is depressed, you have to look out for worn castor bar bushes, lower arm bushes and ball joints, steering linkages, loose or worn slider bolts and improperly torqued wheel lugs.
Apr 9, 2021 at 5:49 AM
1CLAYTON3
Thanks 2CarPros team. This has saved me lots of energy and time away from my job. You guys are the greatest!
1Clayton3
