1998 Honda Accord Tune Up
78,000 MILES • 4 CYL • 2WD • AUTOMATIC
DESICHEMIST
  • 5 POSTS
The car stops sometimes. Usually after starting it stalls. With some gas, starts again and runs fine. Happens a few times in the last month. None of the indicator lights (engine) light up on the panel sggesting anything is wrong in the engine. I have not doen a tune since 40k miles. The mechanic suggested, oil filter, transmission fluid change, spark plugs, air filter and pcv vlave change (all for @240 in Valencia, CA). He also suggested distributor cap, rotor, spark plug wires and fuel injection servicing (for another $240). Should i do it. Which one's are needed. Thnk you.
Jul 30, 2008 at 11:05 AM
KHLOW2008
  • 41,812 POSTS
Hi desichemist,
The first 240 would be well spent but not the second.
Since the engine is stalling, I would suggest cleaning up the throttle boby and checking the main relay.
Aug 1, 2008 at 10:25 PM
