Hi E. BEL1983,
The interlock system is not working correctly and preventing the shift lever to be moved out of Park.
With ignition turned to ON, depress the brake pedal and listen for a click under shift lever. If noise is heard and you are not able to shift out of Park, the interlock solenoid is not moving far enough to release the shift lever lock.
If no noise is heard, check the brake lights. If they do not come on, check the brake switch and fuse.
The horn is not related to the above. Check the fuse and if you have the SRS ( if equipped ) indicator showing, the cable reel under the steering wheel is bad.
Tuesday, February 23rd, 2010 AT 12:31 PM
