1998 Honda Accord Tail lights
80,000 MILES • 4 CYL • 2WD • AUTOMATIC
MEDIEVALHORN
Tail lights come on when lights are activated but do not light up when brake is applied. The side and middle brake lights come on, so I think the brake switch is okay. Have already replaced bulbs and checked fuses and found no problem. What might cause this?
Aug 31, 2008 at 4:33 AM
KHLOW2008
  • 41,812 POSTS
Hi medievalhorn,
If the high mount brakes works, you need to check the brake bulbs and/or its sockets. Did you use the correct bulb type, it should be of double filament.
Sep 1, 2008 at 2:55 AM
