1998 Honda Accord Squeels
201,000 MILES • 6 CYL • 2WD • AUTOMATIC
DEADHEAD
Ive had a problem for the last couple years. When I use the A/C, defrost or rear defrost my car makes a squeeling sound. If i am travelling at a constant speed it only squeels ever so often and momentarily and I feel a little tug. But if I am in stop and go traffic it squeels loud and for a long time until i rev up the engine. The problem began after AI had the AC charged (i think they may have overcharged it causing strain on the compressor bearings. I have been told that it was the belt which i replaced and was not the problem. Any ideas. tension in flywheel? bearings in compressor? What can i do to fix the problem?
Nov 9, 2008 at 6:08 AM
IMPALASS
  • 3,112 POSTS
Hello
From what you are describing your belt is slipping and needs changing. I would change them both and your belt tensioner. Especially with the miles you have on your vehicle.
Nov 10, 2008 at 3:50 PM
