1998 Honda Accord Squeels
DEADHEAD
  • 1998 HONDA ACCORD
  • 6 CYL
  • 201,000 MILES
Ive had a problem for the last couple years. When I use the A/C, defrost or rear defrost my car makes a squeeling sound. If I am travelling at a constant speed it only squeels ever so often and momentarily and I feel a little tug. But if I am in stop and go traffic it squeels loud and for a long time until I rev up the engine. The problem began after AI had the AC charged (i think they may have overcharged it causing strain on the compressor bearings. I have been told that it was the belt which I replaced and was not the problem. Any ideas. Tension in flywheel? Bearings in compressor? What can I do to fix the problem?
Sunday, November 9th, 2008 AT 2:08 PM
IMPALASS
  • 3,112 POSTS
Hello
From what you are describing your belt is slipping and needs changing. I would change them both and your belt tensioner. Especially with the miles you have on your vehicle.
Monday, November 10th, 2008 AT 11:50 PM
