1998 Honda Accord Frame
1998 HONDA ACCORD
67,000 MILES • 6 CYL • FWD • AUTOMATIC
DOVERMAC1
I have a small piece of the frame under the air conditioner where it has rusted significantly. The car has been religously rust protect however, this one spot is quite bad. I also have a hole in the gas tank do I have to replace or is there another option. can I have the frame welded is this expensive?
Sep 15, 2010 at 6:02 AM
KHLOW2008
  • 41,814 POSTS
Hi dovermac1,
The body can be repaired by welding. Cost would depend on how big an area and location. Without a visual, it is not possible to provide any costing and prices ranges region to region. The best is to get a quotation from local sources.
As to the leaking fuel tank, repair is not recommended. Replacement is required.
Sep 16, 2010 at 7:15 AM
