After starting the car we push the button in on the stick shift but it will not move out of park. Can not move it into any other gears.
Jun 10, 2008 at 3:10 AM
KHLOW2008
✓Experienced Mechanic
Hi paulab,
Check for a faulty brake switch or blown brake fuse.
Use the ignition key to insert into the small slot near the shift and press, then shift to N and you can start the vehicle and shift gears. However do not shift into P while stopping at lights until you get the problem solved.
Jun 10, 2008 at 3:20 AM
PAULAB
MEMBER
Hi KHLow2008,
Thank you for your quick response. Will certainly try this as soon as we get home this evening.
