Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Honda
Accord
Drivetrain
Transmission
Gear Selector
1998 Honda Accord Shifting gears
1998 HONDA ACCORD
165,000 MILES • 6 CYL • 2WD • AUTOMATIC
PARVRIES
MEMBER
My problem is that there is a delay in the shifting from 1st gear.
Aug 25, 2008 at 3:51 AM
KHLOW2008
Experienced Mechanic
Hi parvries,
Is the D4 light blinking?
Are gear shifting normal for others?
Did you check the trans fluid level?
Aug 26, 2008 at 2:01 AM
PARVRIES
MEMBER
No D4 light blinking
all other gears shift OK
Transmission fluid changed twice with ATF Z1 from Honda
Aug 27, 2008 at 8:59 AM
KHLOW2008
Hi parvries,
Most likely source of fault would be the linear solenoid. If not the trans is running out of time.
Aug 28, 2008 at 1:24 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
