HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Accord
Drivetrain
Transmission
Gear Selector
SPONSORED LINKS
1998 Honda Accord Shifting gears
PARVRIES
MEMBER
1998 HONDA ACCORD
6 CYL
2WD
AUTOMATIC
165,000 MILES
My problem is that there is a delay in the shifting from 1st gear.
Monday, August 25th, 2008 AT 10:51 AM
KHLOW2008
MECHANIC
Hi parvries,
Is the D4 light blinking?
Are gear shifting normal for others?
Did you check the trans fluid level?
SPONSORED LINKS
Tuesday, August 26th, 2008 AT 9:01 AM
PARVRIES
MEMBER
No D4 light blinking
all other gears shift OK
Transmission fluid changed twice with ATF Z1 from Honda
Wednesday, August 27th, 2008 AT 3:59 PM
KHLOW2008
MECHANIC
Hi parvries,
Most likely source of fault would be the linear solenoid. If not the trans is running out of time.
Thursday, August 28th, 2008 AT 8:24 AM
Please
login
or
register
to post a reply.
Related Transmission Gear Selector Content
1998 Honda Accord 1998 Honda Transmission Probelm
I Am Having Trouble With A 1998 Honda Accord Dx Automatic Transmission. The Transmission Seem To Be Slipping Out Of Gear. When The Car Is...
Asked by
Trell
1 ANSWER
1998
HONDA ACCORD
1999 Honda Accord Gear Shift
Hi, I Am Recently Starting To Have Problems With My Gear Shift. I Push In The Thumb Button As Well As The Brake, However It Will Not Shift...
Asked by
AMBERMAYNES
1999
HONDA ACCORD
My Gear Shift Has Been Locking Up In The Parkied Position. Sometiems The Only Way To Get It To Realease Is To Press Hard On The Brakes.
Asked by
valskin75
1 ANSWER
1999
HONDA ACCORD
High Revving, Gear Shifting?
Hi There, My Car Is Having A Problem With High Revving - Both While Idle And Driving. It Is Having A Hard Time Shifting Gears - Going...
Asked by
bettycoltrane
1 IMAGE
1997
HONDA ACCORD
1996 Honda Accord Gear Shift
Hi, I Am Unable To Put My Car Into Gear. The Only Gear That I Can Remotely Try Is The Reverse And The Gears Grind When I Do This.
Asked by
Eansmom
1 ANSWER
1996
HONDA ACCORD
VIEW MORE
SPONSORED LINKS
Code Read Retrieval/Clear Mercedes Benz
Throwout Bearing - Secondary Cylinder Replacement
Check Engine Light
Online car repair manuals
