1998 Honda Accord question about the answer i was given
121,000 MILES • 4 CYL • FWD • AUTOMATIC
KTANGELBABY8
  • 6 POSTS
i think ill try replacing my spark plug wires first. i was also wonder what a TPS was. and is it an oil pressure sensor you were talking about? thanks for the help.
Jun 15, 2008 at 2:10 PM
BMRFIXIT
  • 19,053 POSTS
TPS (throttle position sensor )
its located at the side of the throttle body
and it has no connection to the oil pressure switch
oil pressure switch is located at engine side
and if you are changing the spark plugs you should check and or change the wires too
Jun 15, 2008 at 2:44 PM
