1998 Honda Accord overheats
DGRG006
  • 1998 HONDA ACCORD
  • 6 CYL
  • FWD
  • 174,000 MILES
Hi, I have a 1998 honda accord ex v6. The car runs fine and all, but an some hot days I turn on the air conditioner and the car eventually heats up. I'll turn it off and it goes back to normal operating temp. What do you think is wrong
Sunday, August 30th, 2009 AT 11:47 AM
Check the thermostat and also if the cooling fans are coming on.
Sunday, August 30th, 2009 AT 2:30 PM
DGRG006
I have replaced thermostat, and checked the cooling fans, both are working.
Sunday, August 30th, 2009 AT 3:45 PM
Could be airlock try bleeding it don't work get it block and pressure tested. Is it actually overheating or just the temperature gauge indication? No actual overheating could be the coolant temperature sensor or the engine temperature gauge switch out of calibration.
Sunday, August 30th, 2009 AT 3:51 PM
DGRG006
No no actual overheating just gauge indication
Sunday, August 30th, 2009 AT 6:02 PM
Could be the guage itself out of calibration, the coolant temperature sensor or the engine temperature gauge switch
Sunday, August 30th, 2009 AT 7:05 PM
