1998 Honda Accord Overheating with airconditioner on
170,000 MILES • 6 CYL • FWD • AUTOMATIC
TOCYN
I recently aquired a used honda accord 1998, V6. When the airconditioner is left on for a bit the car starts to over heat. I can confirm that the radiator is not leaking.
It is apparent that a number of users have experienced this challenge as well. I will be delighted to find out what the trouble might be.
Jul 22, 2009 at 2:40 AM
  • 75,988 POSTS
Are the cooling fans coming on when AC is in use??
Jul 23, 2009 at 1:29 AM
TOCYN
Yes they are coming on and they stay on long after the car is powered down.
Jul 23, 2009 at 2:45 AM
  • 75,988 POSTS
Try replacing the thermostat -that don't work could be clogged radiator, defective water pump. if it continues to overheat get it block and pressure tested.
Jul 23, 2009 at 8:41 AM
