1998 Honda Accord Not sure if alternator is working
1998 HONDA ACCORD
157,000 MILES • 6 CYL • FWD • AUTOMATIC
DOANEY
After sitting idle for several months, I charged up the battery and started the car to drive it a few miles to test all the systems. It started up fine and ran well. i turned on the AC and it ran fine. On the return home, the dashboard warning lights all started to come on flashing a few times then the car would not continue moving in drive i had to down shift to "2" to keep moving.
Once home I tested the battery and it was very low and the car would not start. After recharging the battery the next day it started right up.
The only diagnostics I did was
Battery voltage (not running) 12.8 VDC
Voltage at battery terminals with engine running 11.5VDC
Alternator light on dash is NOT lit with engine running.
Is this proof the alternator is shot? Is there another test I can do or can be done to know for sure?
If the alternator needs to be replaced is this a fairly easy job. What is involved with replacing it?
Thanks
Carl
Aug 13, 2009 at 12:27 PM
F4I_GUY
  • 3,302 POSTS
Yes the alternator is shot. Replace it.
It is not very difficult on that vehicle, remove the power steering pump and you have access to the alternator.
Aug 14, 2009 at 10:21 AM
