1998 Honda Accord No Power to Fuel Pump
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
HARLEY123
Car will not start, seems that there is no power going to fuel pump. Tried replacing fuel pump, still will not start, any ideas, thanks,
Mar 16, 2010 at 1:51 PM
BLUELIGHTNIN6
  • 16,542 POSTS
hello and thanks for donating!
if you believe no power to fuel pump then the first thing to check would be the fuse for the fuel pump circuit. if its good then move on to checking/testing the fuel pump relay. if this is OK as well then the wiring harness at the pump should be inspected.
Mar 17, 2010 at 12:02 AM
