1998 Honda accord mileage 320000km
JARDINDO
My accord will not start.It worked perfectly until I parked it las Sunday.It turns over well but that is all.I can hear the fuel pump run when I turn the key on.There does not appear to be any spark.The rotor button is turning when engine is cranked.I have checked all the fuses I think.Would you be able to suggest any other things to check?
May 30, 2006 at 1:22 AM
LOSONE
  • 1,616 POSTS
What engine do you have??How long since you have had a timing belt change??
It could be your distributer. I noticed there was one for sale on E bay for $69.00.
Did you set a check engine light before it stopped running?? It still is in the computer of you did. Check it out to see if you might have a cam senore code. Good luck
Sep 28, 2020 at 10:22 AM
