1998 Honda Accord How do you remove the left front axle?
201,000 MILES • 4 CYL • FWD • AUTOMATIC
BRUCE9432
Have everything disconnected and the axle came out a little way and then no more. Is there a clip in the tranny or some kind of retainer that has to be removed? I have used moderate force to pull the axle out but am worried that I will damage something.
Aug 3, 2010 at 3:47 AM
KHLOW2008
  • 41,812 POSTS
Hi bruce9432,
Thank you for the donation.
There is a spring clip for holding the inner shift in position and you need to use a crowbar or large screwdriver to pry the shaft outwards. Take care not to damage the oil seal.
After prying the clip loose, the shaft should come out rather easily.
Note : The outer joint have to be disconnected first.
Aug 3, 2010 at 4:11 AM
