1998 Honda Accord help
112,000 MILES • 6 CYL • FWD • AUTOMATIC
VCANNON
my daughters Honda it sometimes wont start and sound as if it is not firing but it turns over. if you let it sit after a short time maybe 3-5 min and then turn it over it starts (most of the time) I have had it in the shop not a dealer but they could not find the problem any suggestions
Jun 18, 2008 at 12:35 PM
  • 31,937 POSTS
Hi there,
The first thing you will have to do is check if you have spark when it won't start, If there is a good healthy spark i would be checking for injection pulse, and then fuel pressure, these test may be beyond your capability as some special tooling is required. I would also check for set fault codes as well.
Mark (mhpautos)
Jun 18, 2008 at 10:44 PM
