Hi, Actually have a couple problems which may be related. Original issue started a couple years ago where turning the key the engine would crank but not start. Turning Ign on/start/off/on/start/off until engine fires has me thinking it may be the Ign switch. Now the tach and speedo as well as the radio cut in and out occasionally but the engine still runs. Looking at the schematic I see they're all associated with both the drivers side underdash fuse/relay panel and the passenger side underdash fuse/relay panel. Unfortunately, my schematic doesn't show where power to thes fuse panels comes from. My guess is the ign. switch. Anyone have an idea?
Thank You
~Larry
Thank You
~Larry
Nov 1, 2009 at 1:08 AM
