1998 Honda Accord GOT CODES IN FOLLOWING ORDER P1298,P0135,
70,000 MILES • 4 CYL • FWD • AUTOMATIC
EYETOP
HI THERE, i'M HAVING TROUBLE WITH MY ACCORD , I WAS DRIVING AND IT WAS NOT PERFORMING NORMAL. I GOT THE ENGINE LIGHT ON NOW AND ALL THESE CODES CAME OUT . THE VEHICLE IS NOT OPERATING PROPERLY ON 3RD AND 4TH ONLY , VERY SLUGGISH TAKE OFF AND FEELS LIKE NO POWER AT ALL. 1ST AND 2ND FEEL A LITTLE SLUGGISH . I PLACE THE SHIFTER FROM PARK TO REVERSE AND IT WORKS GOOD ,IF I PUT THE SHIFTER ON DRIVE(4) IT MOVES VERY VERY SLOWLY AND IM GIVING ALOT OF GAS . I HAVE CHECKED THE ELECTRONIC LOAD DETECTOR (KOEO)AND IT DOES HAVE (.333V)VOLTAGE AT THE CONNECTOR (ACCORDING TO THE TEST THE ELD AND FUSE BOX ARE BAD)TERMINAL 1 AND GROUND , I ALSO CHECKED THE CONNECTOR TERMINAL 3 AND GROUND (KOEO) AND THERE WAS VOLTAGE OF 4.55V.
I CHECKED ALL THE FUSES AND THEY ALL ARE GOOD. CHECKED TRANS FLUID GOOD ,CHECKED BELTS GOOD. I ALSO CHECKED FOR LOOSE CONNECTIONS. I CHECKED THE OHMS ON THE COUNTER SHAFT SPEED SENSOR HAD 491/OHMS
CHECKED THE MAINSHAFT SPEED SENSOR 461/OHMS
CHECKED TRANSAXLE CONTROL SOLENOID (A) 16.5 AND 16.7
CHECKED THE SHIFT CONTROL SOLENOID B & C OHMS ARE 17.6 AND 17.2 ACCRDING TO MY MANUAL THEY ARE WITHIN SPEC.
Jul 18, 2010 at 5:30 PM
KHLOW2008
  • 41,812 POSTS
Hi EYETOP,
The heading allows a limited number of characters and I believe some have been truncated.
Only 2 trouble codes are shown. What other codes do you have?
If the ELD is tested to be bad, then that should be rectified first. Any voltage faults can trigger other trouble codes due to unexpected voltage changes.
Jul 20, 2010 at 5:09 AM
