1998 Honda Accord Burnt Rubber Smell
KAKEGAWA86
Hi, I have a 1998 Honda Accord with 5speed transmission. The car has 116k miles on it. This past week, after I have driven my car, I can smell a 'rubber' burnt smell from the front hood. Yesterday, I even smelt it inside of my car while I was driving.
I try to check whether there is oil leak, but I didn't find any. Is this caused by the clutch? I bought this car second hand at 99k miles, and I'm not sure whether the clutch has been replaced before.
Please reply, thank you.
Nov 18, 2006 at 6:32 AM
BRUCE HUNT
  • 3,754 POSTS
You can test the clutch for slippage by setting the emergency brake and holding the foot on the brake pedal while letting out the clutch pedal slowly. If the car dies instantly it probably is not the clutch. You should also be able to feel the slippage when you do a take off.
Now, have you considered the thought of the belts slipping?
Nov 19, 2006 at 2:57 PM
Suggested Repair
Test the clutch for slippage by setting the parking brake, holding the brake pedal, and slowly releasing the clutch; if the engine dies immediately, the clutch is likely not slipping. Also inspect the drive belts for slipping, which can cause a burnt rubber smell.
Conversation Summary
The owner of a 1998 Honda Accord with a 5-speed manual and 116,000 miles reports a burnt rubber smell from the front after driving, including inside the cabin, and found no oil leak. They suspect the clutch. The expert recommends a clutch-slip test and checking whether the belts are slipping.
