1998 Honda Accord Dash/Radio has no Power
JMBREVARD
  • 1998 HONDA ACCORD
  • 4 CYL
  • FWD
  • 115,000 MILES
Hello I have checked all my fuses and there is still no dashboard lights or power to the radio.
I don't know what the problem may be and I need to know as soon as you can give me an update.
The original problem was that aftermarket radio was shorting out so I took evrything out and found out that all the electrical tape had dried out and they became loose which cause them to touch metal and short out. I re-taped them all but have no power to Radio, got up the next morning and the dashboard lights were out. I replaced the radio to the original Honda radio and still no light on the dash but I have interior lights and the clock works but there is no illumination there either. Please help so that I may fix theis for my wife so she can get off me. Thanks, Jarvis
Thursday, July 29th, 2010 AT 9:52 AM
KHLOW2008
  • 41,814 POSTS
Hi jmbrevard,
Are the taillights working?
Sunday, August 1st, 2010 AT 4:11 AM
JMBREVARD
All lights are working, the illumination on the dash board does not work. I just don't understand the problem, the lillumination around thr Transmission indicator works until I turn on the Lights. I've had all the fuses checked and they don't kow where its coming from.
Tuesday, August 3rd, 2010 AT 9:11 AM
KHLOW2008
  • 41,814 POSTS
Did you check if the dash brightness control is set to minimum or unplugged? A fault with the unit can result in the symptoms described.
At the radio harness, test the White/Red wire for battery voltage with ignition switch turned ON. It should have battery voltage.
Tuesday, August 3rd, 2010 AT 12:22 PM
