1998 Honda Accord cooling fans
SRUTR5371
Engine Cooling problem
1998 Honda Accord 4 cyl Two Wheel Drive Automatic
The cooling fans in my step-sons accord ex quit working. I am not a mechanic by no means, but suspect the relay switches to be bad. I do not know for sure, and do not know where they are located. Can you help?
Jan 14, 2010 at 3:11 AM
KHLOW2008
  • 41,812 POSTS
Hi srutr5371, Are both fans not working? Did you test the fans by applying battery voltages to them each one at a time?
https://images.2carpros.com/forum/automotive_pictures/192750_FuseboxHood98AccordFig06_1.jpg
Relays are located in underhood fuse box. The fan switch is located on the thermostat housing.
Jan 17, 2010 at 2:37 AM
