1998 Honda Accord check engine light
127,000 MILES • 6 CYL • 2WD • AUTOMATIC
KROGERS2
Hi. I am getting a code for both egr valve and transmission. Car is running excellent. When I disconnect power light goes away, comes back after couple days or high mileage. Is it likely that something is wrong with my tranny? I called a dealer and he told me to bring in for $90 diagnostic, and that even though transmission is working fine I might need new one. Anything I can try at home to figure this out? TIA-Kevin
Aug 8, 2008 at 5:48 AM
KHLOW2008
  • 41,812 POSTS
Give us the exact code and we will see how we can progress from here.
Aug 9, 2008 at 9:20 PM
KROGERS2
Thanks for getting back to me. EGR code is PO401 and tranny code is PO700. I had a tech from a non-honda shop look at it and the EGR tube is clogged, needing the fix from the bulletin where it has to be drilled out. He said the Tranny code seemed erroneous, as he did not have a description for it at "700".
Aug 12, 2008 at 4:40 AM
KHLOW2008
  • 41,812 POSTS
Hi krogers2,
Sorry have to disappoint you. I don't have any more data then you already have.
If you can do a manual bridging of the diagnostic connector to get the manual error code, it might help.
Aug 12, 2008 at 4:49 AM
KROGERS2
Thanks for the help here. Is it likely that the PO700 is erroneous code that should not come up in your opinion? Tranny seems to be operating fine and the fluid looks good, all the way around, but this tech told me there were problems with '98 trannies.
Aug 12, 2008 at 4:56 AM
KHLOW2008
  • 41,812 POSTS
Hi krogers2,
Yes, it is possible. You need a diagnostic scan to confirm the code. Normal scanner would not give you the details.
Aug 12, 2008 at 5:00 AM
