1998 Honda Accord Warning Lights Stay On
ASNAVARRO
MY 1998 HONDA ACCORD JUST CRAP OUT ON ME.
I WAS JUST DRIVING IT AROUND AND MY CHECK ENGIN LIGHT CAME ON ALONG WITH MY BATTERIE LIGHT, BACK LAMPS LIGHT, AND DOOR LIGHTS, AND BRAKE LIGHT. I TESTED IT AND IT GAVE ME A CODE REFERING TO MY SHIFT SILINOID WHICH IS IN MY TRANNY BUT I DROVE MY CAR LIKE THAT FOR A DAY AND THEN MY CAR COMPLETE DIED THE CAR JUST SHUT OFF COMPLETE LIKE THE BATTERIE DIED SO I PUT A NEW ONE AND NOTHING WAKED A DAY AND IT TURN ON BUT WITH ALL THE SAME PROBLEMS. SO HAVEN'T TOUCHED IT SENCE I NEVER HAD A PROBLEM W/ THIS CAR I HAVE 137K MILES WITH A AUTO TRANS AND A 4 CYLINDER LS AND THIS WILL BE MY FIRST PROBLEM AND SEEMS TO BE THE WORST. :?:
Nov 14, 2006 at 6:44 AM
BRUCE HUNT
  • 3,754 POSTS
Hard to read through the information but I assume that the car runs right now but the lights are all on when it is running? Or is just the CEL on?
Nov 14, 2006 at 8:30 AM
ASNAVARRO
[quote:63ca3cfd90="Bruce Hunt"]Hard to read through the information but I assume that the car runs right now but the lights are all on when it is running? Or is just the CEL on?[/quote:63ca3cfd90]
YES, ALL THE INSTURMENT LIGHTS ARE ON WHILE RUNNING THE CAR ALONG WITH CEL THEY NEVER TURN OFF
Nov 14, 2006 at 8:58 AM
BRUCE HUNT
  • 3,754 POSTS
Just a shot in the dark here but play with the starter switch and tapping and wiggling the key will make the lights go off. Sounds like a switch problem.
Nov 15, 2006 at 12:33 AM
Suggested Repair
Check the ignition switch. With the engine running, gently wiggle the key and tap the switch; if the warning lights go out, the ignition switch is likely faulty and should be repaired or replaced.
Conversation Summary
The owner of a 1998 Honda Accord with 137,000 miles reported that the check engine light and several other warning lights came on, followed by a shift-solenoid code. The car later shut off completely. A new battery did not restore it immediately, but it started the next day with the same lights staying on while running. The expert suggested an ignition-switch problem and recommended wiggling the key and tapping the switch to see if the lights go out.
