Alternator Belt Size
170,000 MILES • 6 CYL • FWD • AUTOMATIC
MIKERECHEL
Is there 2 different sizes of alternator belts for the accord. I went to autozone to pick up a new alternator belt and they had 2 sizes. I don't know which one will fit my car. Thanks.
Jan 3, 2010 at 6:16 AM
HONDA TECH 1818
  • 536 POSTS
There is two drive belts in the V6 accord, one is the power steering and the other one is for the alternator, ac, and crank. I would get one from the dealership.
Jan 3, 2010 at 6:58 AM
JOSE ALVAREZ
I would like to replace the power steering pump on a Honda Accord 2002 V6 . My questions is where is the adjustment to loosen the serpentine belt , in order to swap out the steering pump? It is on a friends car , so technically I have not searched for an idler pulley screw of any sort yet . I just want to save time by knowing what to look for before I check under the hood .The part will be in next week .
Thank you , Jose Alvarez
Aug 13, 2019 at 11:53 AM (Merged)
IMPALASS
  • 3,112 POSTS
Hello
There is about 7 different types of Honda Accords, what model is it, DX Sedan, EX Coupe? and the exact size of the engine please.
Thanks
JOSE ALVAREZ
The Honda Accord is a EX Sedan , and the V6 is a 3.0 liter size . Thank you for your help ...
Regards , Jose Alvarez
IMPALASS
  • 3,112 POSTS
Hello Jose Here is the step by step.....specifically step 5 talks about the belt. Good Luck. Replacement Place a suitable container under the vehicle. Drain the power steering fluid from the reservoir. Remove the intake manifold cover.
https://images.2carpros.com/forum/automotive_pictures/248015_1_11.jpg
Cover the crankshaft pulley with several shop towels to protect if from spilled power steering fluid. Disconnect the pump inlet hose (A) and pump outlet hose (B) from the pump (C), and plug them. Take care not to spill the fluid on the body or parts. Wine off any spilled fluid at once. Remove the belt (D) by loosening the pump adjusting nut (E), then remove pump mounting bolts (F), nut (G) and pump. Do not turn the steering wheel with pump removed. Connect the pump outlet hose and inlet hose. Tighten the pump fittings securely. Loosely install the pump in the pump bracket with the mounting bolts and nut.
https://images.2carpros.com/forum/automotive_pictures/248015_2_7.jpg
Install the pump belt (A) on the pulley (B). Note these items during belt installation: Make sure that the power steering belt is properly positioned on the pulleys. Do not get the power steering fluid or grease on the belt or pulley faces. Clean off any fluid or grease before installation. Adjust the pump belt adjustment Fill the reservoir to the upper level line.
