1998 Honda Accord Air conditioning cuts out as engine temp
215,000 MILES • 4 CYL • 2WD • MANUAL
PIZZLEBOY
Hello Team,
I have a 1998 accord with 215,000 kilometers on it. This car is perfect in everyway except when running the air conditioning.
On normal days, the temp needle ranges from about 1/3 - 1/2. If I drive on the freeway while averaging about 120 km/h, it tends to rise to about 1/2 to slightly above half.
On the hot days I usually enjoy rolling up the windows and turning on the AC. When I do this, the gage slowly starts to rise up into the 2/3 to 3/4 range. When the needle his 3/5 or so, the AC cuts out and it start blowing hot sticky air again. I can then turn the AC off, let it cool slitghtly and repeat the process. Keep in mind that the temp needle never gets to the top of the guage.
Needless to say this process happens more quickly the hotter the outside temp is, which is ironically when I want the AC the most :(
I would like to know if there is some kind of saftey switch that is being triggered to prevent engine over heating, of it this is just some kind of anomoly.
Also, what components could I be checking myself to fix this.
Thanks.
Jul 28, 2008 at 4:25 AM
KHLOW2008
  • 41,812 POSTS
Hi pizzleboy,
There is nothing to prevent the engine from overheating but an overheating engine will cause the AC compressor to stop working. Seems the problem lies in the cooling system.
I would suggest checking the radiator for clogging since the problem is aggravated by high speed driving.
Aug 1, 2008 at 4:26 AM
