I noticed the ABS light coming on
57,220 MILES • 4 CYL • 2WD • AUTOMATIC
NOODLES1
I noticed the ABS light coming on. This came on when I test drove the car and was informed that it was only the censor. Now it has appeared, I'm wondering if it is more serious than I thought. My mechanic said that one of the discs was distorted / buckled but could not test the ABS was of the machines they use. Once the new front discs are fitted, do you think this would solve the light coming back on and if not, would I have to go to an approved Honda dealer.
Sep 8, 2008 at 4:20 AM
KHLOW2008
  • 41,812 POSTS
Hi noodles1, Get a scan done to find out what is causing the ABS to show. The error code would inform you what is at fault. You can try by bridging the SCS and counting the flashes to see what is the problem.
https://images.2carpros.com/forum/automotive_pictures/192750_SCS99AcuraTL_1.jpg
Apr 23, 2021 at 6:19 AM
BOOSTEDZ32
Im having a hard time finding this connector please more help
BOOSTEDZ32
It is a 98 accord coup by the way
