1998 Honda Accord !998 Accord EGR Valve Error Code
145,000 MILES • 4 CYL • 2WD • AUTOMATIC
ANNCRYSTAL
Hi :
The maintenance light of my Accord is yellow which is showing up an error code of EGR valve. I took it to a mechanic and he cleaned the EGR valve and cleared the error code.
After two days, the maintenance light turned back ON with the same error code. The I replaced EGR valve with the one which I got from a salvage yard. Same thing repeated, maintenance light turned back ON. He checked all tubes and stuffs and told me that it shows no signals of leaks.
Please help me with some pointers!!! What can be wrong here. How can we find it out other than replacing more parts like Oxygen sensor etc? Is there a way to diagnose better? Please help me.
Thanks for your support
Ann
Jun 11, 2008 at 4:00 AM
KHLOW2008
  • 41,812 POSTS
Hi anncrystal,
Since the part is from a scrap yard, it could be faulty as well. There are a few different types, sure you got the correct one? Check the wire colors and position in connector.
This EGR valve is controlled by a purge solenoid, check that out.
An out of adjustment or inaccurate TPS would also cause the problem.
Jun 12, 2008 at 12:36 AM
ANNCRYSTAL
Thanks KHLow2008. So what are my options? Replace EGR Valve? I didn't really get you.
Thanks for your help.
Ann
Jun 12, 2008 at 3:56 AM
KHLOW2008
  • 41,812 POSTS
Hi anncrystal,
I guess the first option is to replace the EGR again. Make sure the wire colors are the same as your initial pc.
Normally the EGR electrical would show the code and other controlling items would not show but create misfiring etc.
Jun 12, 2008 at 5:20 AM
ANNCRYSTAL
Thanks KHLow2008 for your support! Can I go with after market parts or Should I go with original Honda parts itself (those are expensive:()
Thanks again for your support.
Ann
Jun 12, 2008 at 5:43 AM
KHLOW2008
  • 41,812 POSTS
Hi anncrystal,
I don't know about after market parts because I have always used the original parts from the scrap yard.
In my country exhaust emission system is not compulsory so I haven't replaced many yet as only a few has them
Jun 12, 2008 at 5:48 AM
ANNCRYSTAL
Thank you very much for all your input!
Jun 12, 2008 at 6:30 AM
KHLOW2008
  • 41,812 POSTS
Hi anncrystal,
You are welcomed and it is my pleasure to be of service.
Hope you get your problem solved soon.
Good luck
Jun 12, 2008 at 7:12 AM
