1998 Honda Accord 1998 Honda Accord door lock and windows p
175,000 MILES • 4 CYL • FWD • AUTOMATIC
1DUMTURD
I have a 1998 Honda Accord sedan. It just rained yesterday and today my automatic door locks won't function through both side of the door switches or lock/unlock through my keyless remote entry.
The window controls, on driver side, for the automatic windows only function for the left side of the vehicle and does not work for the right side passenger and back windows. However, the controls work on the individual doors.
What's going on here? Any suggestions on where to start?
Oct 15, 2009 at 6:03 AM
KHLOW2008
  • 41,812 POSTS
Hi 1dumturd,
Did problem occur only after it rained?
Was the windows left open allowing rain water to get onto the driver door main control switches?
Oct 18, 2009 at 6:11 AM
1DUMTURD
I had the problem resolved. It had something to do with the wipers intermittent speed controller. Apparently this is a common issue for this model. All I had to do was put the car in ignition position 2 and twist the speed controls up and down and the windows control panels were functional again.
I used the wipers on the day that it rained and I guess that wipers speed controller decided to go bonkers.
Oct 19, 2009 at 7:07 AM
KHLOW2008
  • 41,812 POSTS
The multiplex system controls the wipers and power windows so that should be the cause of the problem.
Using the wiper should not cause any problem unless you have a fault in the system. It could be intermittent and might recur anytime.
Sometimes resetting by disconnecting the battery or pulling the fuse works.
Glad that you have resolved your problem.
Oct 19, 2009 at 11:43 AM
