1998 Honda Accord
TRILLASINCE1990
  • 1998 HONDA ACCORD
1998 Honda Accord 4 cyl 90,000 miles
Hey,
Sometimes when I turn I hear a grinding sound, and also my check engine light was on and I changed the oil then a day later it came back on. Not far ago my car used to jerk while I place in to drive and reverse and woulkdnt accelerate so I got a new transmission. Now that I have a new one, the car doesnt seem to switch gears as well and smooth as before. HELP ME
PLEASE CARPROS
Monday, July 26th, 2010 AT 8:49 PM
F4I_GUY
  • 3,302 POSTS
The grinding noise is most likely a wheel bearing
Your engine light is on because you have a fault somewhere in your fuel management system. Have a technician scan and diagnose it. It could be a quick fix!
For the transmission issue, have the mechanic who put the transmission in, take a look at the engine and trans. Mounts. They may be worn out.
Monday, July 26th, 2010 AT 10:49 PM
TRILLASINCE1990
What is a wheel bearing?
Tuesday, July 27th, 2010 AT 2:32 PM
KHLOW2008
  • 41,814 POSTS
Sorry for the delay as our technician handling your question is not available at the moment.
The first diagram is the knuckle assy and the 2nd diagram is an exploded view of the knuckle showing where the wheel bearing is located inside the knuckle for the front wheels.
https://www.2carpros.com/forum/automotive_pictures/192750_FrontSuspension97AccordFig01_2.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_FRTKnuckle98AccordFig02_1.jpg
Sunday, August 1st, 2010 AT 11:57 PM
