1997 Honda Accord vacuum
DAHEAT
Engine Mechanical problem
1997 Honda Accord 4 cyl Front Wheel Drive Automatic
how to lowcate a vacuum leak
Nov 10, 2008 at 2:50 PM
LEGITIMATE007
  • 5,121 POSTS
a simple way to do it is take some brake clean and gently mist it around the intake manifold and around the vacuum lines, if there is a change in the idle, then your leak is in the vicinity at which you sprayed the mist. usually a vacuum leak will cause an engine light to be displayed on the dash, and also you will have an increase in idle.
Nov 10, 2008 at 3:02 PM
