1997 Honda Accord turn signals
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
KSCHACHT
Car was in minor accident damaging driver side front side light and signal light. Side light replaced and working . Turn signal light damaged but electrical looks ok. None of the turn signals worked (front or rear) .. found blown fuse and replaced it. Now the rear turn signals blink rapidly and neither front signals work at all. Emergency flasher works normally in the rear .. fronts do not work at all. Is this a relay or flasher .. and if yes .. where are they located ? OR .. am I looking at a short ?
May 18, 2008 at 12:40 AM
LEGITIMATE007
  • 5,121 POSTS
well if you've checked the bulbs in the front of the vehicle. then I would go for the flasher next, that could ve shorted out too seeing that there was a blown fuse courtesy of the accident. the flasher is at the top of the fuse panel
May 18, 2008 at 2:25 AM
