1997 Honda Accord to hot
1997 HONDA ACCORD
150,000 MILES • 6 CYL • AWD • AUTOMATIC
JANICE MUHME
What would make my radiator get boling hot and then losses everything from the rasavor? I have changed and checked so many things. The radiator has no leaks and the cap is good.
May 3, 2010 at 3:15 AM
KHLOW2008
  • 41,814 POSTS
Hi Janice Muhme,
If the reservoir is drying out, then there must be a leak in the cooling system.
If the radiator is getting too hot and coolant is being pushed out to the reservoir, either you have a bad head gasket, fans not working or the thermostat is stuck.
May 5, 2010 at 6:06 AM
JANICE MUHME
where is the head gasket located on the 1996 honda accord?
May 10, 2010 at 3:31 AM
JANICE MUHME
Where are and how many sensors are there for the radiator heating and cooling system?
May 10, 2010 at 8:30 AM
