1997 Honda Accord Throttle Position Sensor
104,000 MILES • 4 CYL • 2WD • AUTOMATIC
H22A ACCORD
hey guys i have a 1997 4 cyl Honda Accord with a H22A Engine.....wen i drive the car on normal roads...an press down on the gas...the car often seems to buck an miss while the TPS Sensor is flashing....once the TPS is turned off i do not have that Problem....wat could be the cause of that?
Sep 2, 2010 at 10:34 PM
  • 75,988 POSTS
Test the TPS sensor, closed idle and WOT voltages
Sep 3, 2010 at 7:07 AM
