It sounds like the issue is a malfunctioning brake light switch.
The brake light switch is located under the brake pedal.
When the brake pedal gets depressed it pushes against the switch, which triggers the brake lights to come on.
Over time with normal wear and tear the switch can malfunction. It is probably shorted to the on position and that is why the brake light is staying on.
Here is a helpful video:
https://youtu.be/RBCDVfzNQGk
Images (Click to enlarge)
Nov 5, 2021 at 3:56 AM
